Deepwater
- Apr 20, 2015
- New Brunswick
- 2011 Vector LTX
Just bought a 2012 and would like to stud it. Do the issues pertaining to clearance on the 2010 apply to the 2012. Looks like protectors for the heat exchanger are already installed. Just want to make sure they provide enough clearance
chuckpp
- Mar 27, 2013
- Belmont N.H
- 2016 Yamaha srviper ltx dx
I have the same sled and I put 1 1/2" check out this thread...
http://www.ty4stroke.com/threads/anyone-who-studded-a-2010-vector-ltx-read.88497/
Deepwater
- Apr 20, 2015
- New Brunswick
- 2011 Vector LTX
Thanks saw that thread. Is there any difference between 2010 tunnel protectors vs 2012 or do I still need to add additional clearance?
chuckpp
- Mar 27, 2013
- Belmont N.H
Yes you do !!!Thanks saw that thread. Is there any difference between 2010 tunnel protectors vs 2012 or do I still need to add additional clearance?
Deepwater
- Apr 20, 2015
- New Brunswick
- 2011 Vector LTX
Dusty Dan
- Jan 24, 2015
- 2016 SRViper LTX LE
2012 Vector
I have the same sled and installed studs 2 years ago. I called my dealer about protection and was told I did not need it with that sled. I like to be careful so called another dealer and got the same answer. I put 108 up the middle and have had no problems after more than 13,000 km.
Good luck,
Deepwater
- Apr 20, 2015
- New Brunswick
- 2011 Vector LTX
Thanks, Do you recall what length studs you used?
chuckpp
- Mar 27, 2013
- Belmont N.H
Call woodys and they will tell you what to used...thats what i did//
Dusty Dan
- Jan 24, 2015
2012 Vector
My recollection is 1 3/8 but as Deepwater has suggested your best bet would be to call. I used Woody's and am very happy.Thanks, Do you recall what length studs you used?
Dusty Dan
- Jan 24, 2015
2012 Vector
Forgive my error. it was chuckpp who suggested calling. What the heck, I'm a newbie, lol.My recollection is 1 3/8 but as Deepwater has suggested your best bet would be to call. I used Woody's and am very happy.
Stock Ripsaw requires a 1.325 stud length
up.mi.man
- Feb 23, 2009
- Marquette MI
- 2017 sidewinder ltx se
- Marquette Mi right on trail 417
fast trac says 1.375.
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
- 2013 Yamaha vector ltx
My stock 1 1/4 inch ripsaw takes 1.325 woodys.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
I would definitely install additional tunnel protection on, we used an set of cut offs from a pair of slides, riveted on to the existing tunnel protectors
