jlvose
- Feb 6, 2015
- Gray,Maine
- 2/2002 yamaha sx viper/2000 yamaha sx700r
I have a 2002 yamaha sx viper.Origional track is .92 in height Ibelieve.Just purchased almost new Camoplast Ripsaw 1.25" track for 150.00. Do I have enough room to run studs(120) up the middle?Or is the track lugs too tall? Woodys said to roll it on its side and take a look.Suggested 1.375 studs? This is all new to me! Thank you,Jeff (Maine)
On my old 02 Viper I installed a 1" Ice Ripper and needed to trim the track where the protectors were. You can run the 1.25 but will need to remove the protectors thus making nearly impossible to run studs.
I think changing to 8" drivers may make it possible.
You may want to register on the 2Stroke side of TY to get more info on your Viper
http://www.totallyamaha.net/forums/forum.php
The 1.375 is the correct stud height for the 1.25 track
jlvose
- Feb 6, 2015
- Gray,Maine
So I can run the track the way it is,minus the studs?Or do I have to shave the track to fit? Thanks again,JeffOn my old 02 Viper I installed a 1" Ice Ripper and needed to trim the track where the protectors were. You can run the 1.25 but will need to remove the protectors thus making nearly impossible to run studs.
Yes. Remove tunnel and front exchanger protectors. The track will then clear without trimming.So I can run the track the way it is,minus the studs?Or do I have to shave the track to fit? Thanks again,Jeff
