Fishcrib
- Nov 28, 2009
I just put 96 studs on the phazer. I did not put a tunnel protector on. Looks like plenty of clearance between exchangers and studs. I know they recommend the protector. Anyone else running studs without the protector?
Rove44
Thats a good question i just picked up an 08 phazer for my wife also have 96 woodys' i have'nt studded it yet trying to pick up a set of used protectors on this site. I am leary of studding without protectors..
Prav
Rivet an old set of Hifax under the tunnel... cheap easy way to ensure you won't tear up the back end of your sled. I would never ride a studded sled without protectors.
xt_gt
don't have any on mine but have some markings of when i jumped on the rear & pinched the throttle.(dumb move on my part) marks are just on the rear hole where covered.
under avg. riding, not jumping it, just trail riding you can probably get away with none.
(but i know not recommended.)
zackn291
I got 96 studs and their is a few marks but nothing worth worrying about.
QUADSCRIB
I think the potential consequences are too much vrs. $100.00 protectors.
Just get them on it Id say. I bought some and dont even have studs yet.
My Buddies Polaris learned the hard way..... Im protecting my Phazer from day one...not worth the risk.
Put the protectors in..... definately not worth the damage if you dont..... my 2 cents.
marpolsdofer
Just use the older type hyfax.
Motoman765
- Dec 12, 2006
- Michigan
- www.teamfsr.com
I would definitely put them in. Here is a link to an old post of mine with pictures of what happened to my sled without the protectors. I thought they would clear, but that was not the case. Didn't go through my exchanger but it came close at one point.
http://www.ty4stroke.com/viewtopic.php?t=52135
marpolsdofer
What size stud is that.
fraolib
probly 1.075
Motoman765
- Dec 12, 2006
- Michigan
- www.teamfsr.com
That was my stock track the first year I had the sled and those are 1.080" Studboy Power Points. Now I have the freeride on the sled with 1.625" Power points.
fraolib
jesus those are big. im surprised u didnt do double backers i have the 1.5 freeride and i was told studs wouldnt fit.
Motoman765
- Dec 12, 2006
- Michigan
- www.teamfsr.com
Well someone told you wrong. I've run this track for two years now with no problem.
marpolsdofer
I was just asking becaues they looked a little taller then 1.080. I just didnt think the 1.080 could get theat close, but then again I am lighter.
