09nytro
don't know , I would guess no just by looks and feel
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
The newest update was in 2010 (8GL-21940-02-00) which was suppose to have stronger gussets. I believe the 2011 Nytro has had no change to the frame. Even with the update in 2010 there have still been many reports of the newest version bending. I replaced the subframe last summer with a 2010 version and welded reinforcement gussets in. I've taken some hard hit this season which I believe would have bent the subframe but so far everything is still straight.
mjaremko
Suspended
Grizzzzz,
Do have any photos handy of your upgrade ?
Do you sell the upgrade ?
mj
mj
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
The reinforced subframe has worked well for me. Several others have done the same or a similar mod. I haven't heard of anyone bending a subframe since installing gussets so I believe their helping. Here is some info and a link to additional pictures. PM me if you need more info.
http://www.ty4stroke.com/viewtopic.php? ... t=subframe
canuk77
I just got a new subframe from Cycle Parts and it was $410us + $140 shipping,it was $900 cnd + taxes.It also had the plate in the front and the back part where it gets wider had a plate to cover in the first 4" of the belly pan.It looked alot stronger than the 08 but i will add the xtra bracing in the summer...
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
$900................HOLY #*$&@
mjaremko
Suspended
Thanks Grizz.
mj
mj
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
need a subframe anyone have a 2010 or newer they are willing to part with? not bent of course
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Ha...someone having a spare subframe that's not bent...that's a good one.
mjaremko
Suspended
whats a slightly bent one worth, $ Anything ?
mj
mj
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I've straightened a slightly bent 09 frame and reinforced it with my gussets then sold it. I'd be willing to buy a slightly bent 09 or newer frame for the right price.
mjaremko
Suspended
Grizz,
What might the right price be ?
Mine has a slight crease across the flat plate with the large round hole in it.
mj
mj
09nytro
I have grizz reinforcment plates been good so far
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
grizz, if you get a frame that you have your gussets on I would be interested in buying it
