<<<At what angle do I want my tunnel to be at when I make my measurements to relocate the mounting holes???? When the suspension has all weight off it (raised), pick up the rear of the sled and "place" it back on the ground (natural) or have someone the same weight as I am sitting on it (riding). The difference between these 3 tunnel angles changes the relocation points drastically.>>>
After reading the universal mounting directions (twice!), they don't do a very good job of something you're asking about here, and that something I think is the absolute key on a project like this - the place most guys get in trouble. That's taking front end ride height into account when setting the front skid mounting height within the tunnel - or, as you put it, setting up the angle the tunnel runs at.
Here's what I wrote when kinger asked about lowering his skid for increased clearance:
If the sled is handling well now, I would get the (unloaded!)height dimension of the front end prior to modifying or changing anything. Then figure out a way to support it securely at that same height so you can dink around with the back end without it falling down or changing. Maybe somewhere in the area of the lower front a-arm mount?
From there, I'm not familiar with how the ZX mounts. But if it were a Poo/Cat/Doo suspension, I would measure from the ground up to both the front and rear mounting points, with the sled unloaded, and prior to any work, with the front end blocked. (as it turns out the ZX is not much different)
Then I'd drop/pull the suspension, lift the back up the amount you want, hold it there, and measure the front mounting point to see how far it moved. That's the distance you'll want to drop it for the amount you've lifted the back to stay "in sync" front/middle/rear.
Blocking the front end prior to doing any of this is critical. If you skip that step, there is no doubt you'll end up with your front skid mounted too high.
Does that answer your concern regarding the angle of the tunnel?
