Tomelongname
Springs, spindles & bumper done. Now rear bumper & skid.
Question: read a lot about the cat center shock spring 95/250 & the 160 for the LTX. Or should I just do shocks and have recalibrated? 64 years and 90% trails in eastern Manitoba
Thanks folks
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Shock revalve for your weight,springs and riding style seems to be what most guys are happy with in the end
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I Installed a 160# spring on my XTX, but haven't tested it yet. I had to put 8-10 turns on the stock 110# just to lighten up the steering effort and get the skis off the ground a bit under hard throttle. Just playing around in the garage it's seemed to make a difference, been able to drop about 15 psi on my rear float to get the proper set-in and I can actually get the sled to rock back and forth on the center shock. Your LTX should have a 135# so I'm not sure how much of a difference a 160# would make.
i used the CAT dual rate center spring with re valve and softer torsion springs. rides like a caddy
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
Cannondale27 revalved the shocks on my XF7000, which is an LTX. Totally worth the $$$. He’s very affordable. It made a big difference. I don’t cringe in the bumps anymore. Now all I need to do is upgrade the rear skid parts to steel RR parts.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
X2 on Cannondale27's shock service! Had him re-valve my shocks and add EVOL chambers for next season.
snowman8
- Jul 26, 2016
- NW Indiana
- Viper LTX LE & Phazer GT
- Schererville, IN
Anyone tried the Hygear multi rate springs for the center shock? Feed back?
https://www.hygearsuspension.com/co...s/center-dual-rate-pro-series-spring-kit-snow
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
I used hygears dual spring kit on my 2011 apex xtx and did progressive valveing on shocks and it improved the ride 100%, i kept spring and i am gunna try it on my 19 sidewinder to see how it works.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Put it in 16ltx laat year and I'm very happy with itAnyone tried the Hygear multi rate springs for the center shock? Feed back?
Tomelongname
Back together. Powder coated springs, spindles, bumper, rails ✔ AC Dual rate center spring ✔revalved shocks ✔
hellflyer
- Dec 2, 2008
Looks good!
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Looks sharp!
DVW
- Nov 14, 2017
- Prior Lake Mn
- Arctic Cat 7000
Most dual rate spring applications have the softer low rate portion active in normal operating conditions. However it was my understanding that the Cat dual rate center spring was designed for more steering authority not softer ride. Despite this I bought one and tried to adjust it to give me better ride. I did not have much success. After working with it I could see how it could give more steering authority (with more effort). To get more authority you can have less preload on the center spring without the spring getting loose when the track is off the ground and hanging on the limiter strap. However when the spring was compressed with my weight (200 lbs) I was into the high rate portion of the spring. I could not get a better ride with the adjustments I made.
Tomelongname
Now you tell me, darn. Hopefully the revalving will help. It was $50, so it a big expense. Have a great long weekend.
Tomelongname
Looks sharp!
It was either that or replace the FXR clothing. Son manages a powder coating shop so he did it for $0.00.
