Summerizing the beast
snowman
labrador coast
What things have you done to store your sled for the summer?
I put my sled away 2 days ago and don't know if i should put abit of oil in the heads for the summer like we do for 2 strokers.
I removed fuel lines from tank and sled ran for 7.5 mins on the gas left in carbs 8) 8) 8) :D :D :D
i just draned the tank, ran the sled about 1/2hr to run gas out , then draned carbs , carbs still had some gas in each one . Should be rady to start in the winter . I never put oil in motercycle so i don't think the RX1 needs it . I also greesed up the suspention in case there was any mosture in the shafts.
Tom-RX1
Replace Chaincase oil ( Use Synthetic) Adjust tension
Sta-Bil Gas treatment
Lubricate Chassis with synthetic grease
Remove Drive Belt and spray clutch faces with silicone to prevent oxidation
and when you bring it back into service clean with alcohol
Trickle charge battery once a month
Replace engine oil and filter ( Use Synthetic) when bringing back to service
:D
