Tuning Forks
- Nov 26, 2003
Have a ulmer stage 3 clutch kit for a 04 RX1. Would like to know if the base wts. will work on a apex gt.
suburban
They should be fine, you would just need to add a little more tip weight for your apex.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Contact us at Ulmer Racing. We have setups to use the old style weights in the Apex. They require a completely different washer orientation than what we used in the RX-1. More heel weight and tip weight and no weight in the middle.
Tuning Forks
- Nov 26, 2003
Thank-you allen. I'll give you a shout to find out how much heel & tip wt. to add to supertips.
