fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
You wouldn’t, stock clutching is set for stock sled, tuned sled makes more power which means it revs more and now needs new heavier weights and other stuff to make it work rightYep yep done tuned already don’t remember banging on rev limiter before tune
Turboflash
- Mar 18, 2019
- Southern MN
IMO, tuned sled (260+ HP or more) MUST shift up much faster or it will hit rev limiter.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Selling those?I got two sets of stock weights from 17 and 22 sidewinder.. You need a set?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Pm sent.Selling those?
Fast
- Sep 25, 2018
Why can't we use polaris weights? Been running them in my apex since it was new 66 gram just had to grind the tip a bit so they clear, best upgrade i didI would never even consider this unless it got me out of the woods on a break down.
Get a new dealer
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
You can do whatever you like.. Just stating I would rather run a adjustable weight/ OR Yamaha weight not a Polaris weight unless I had to for some reason. If they work and it fits your needs or wants great..Why can't we use polaris weights? Been running them in my apex since it was new 66 gram just had to grind the tip a bit so they clear, best upgrade i did
beanie
- Jun 11, 2005
if you still have a stock set of weights p[ease let me know , I have a 17 ltx-le with 8lr-00I got two sets of stock weights from 17 and 22 sidewinder.. You need a set?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Sold one set awhile back. Can’t seem to find the other? Sorry I couldn’t help you out.if you still have a stock set of weights p[ease let me know , I have a 17 ltx-le with 8lr-00
Turbo 998
- Mar 30, 2016
- LeSueur MN
- 2017 Yamaha Sidewinder LTX LE, 2014 Yamaha Viper LTX, 2001 Arctic Cat ZR800, 2- Yamaha SS440, Yamaha Enticer 250, Scorpion lil whip, Scorpion Super Stinger
- yes
I have my stock weights sitting in my garage if someone needs a set. They are from a 2017 LTX LE with about 500 miles on them.
beanie
- Jun 11, 2005
Thanks 4 the responceSold one set awhile back. Can’t seem to find the other? Sorry I couldn’t help you out.
beanie
- Jun 11, 2005
How much you want shipped to 54455?I have my stock weights sitting in my garage if someone needs a set. They are from a 2017 LTX LE with about 500 miles on them.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
This is great news! I will be running MS16 and assumed I would need some new weights even with the XS825. Did you do anything to the secondary?Same here. I'm running Max Spool 16 with stock weights and an X2825 belt. It revs 9,000 and the belt has been more durable as well.
- 14K
