I have one tungsten and two washers in the toe
I have 4 washers in the mid.
two washer in the heel
When I take off it flash 10,500 and pulls down to 9500 right away.
What changes would I need to make to keep me a 10,500?
Thinking I need
6 washers in the toe
2 in the mid.
2 in the heel.
Does this sould right.
thanks for the help.
Thinking I need
2 in the mid.
2 in the heel.
TurboJamie
Move the weight from the toe to the heel and the heel to the toe.
Need for Speed 2
heel 2tungstens tune mid and top from there. grab that belt hard with that wee little circle leaving then things get tuned from there.. give us more specs on your ride might be able to help more.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I have to ask, what power are you putting out, do you have a SC or turbo installed? Please be be spesific and add more info on your sled, and you will get the help you need. What clutch setup do you run..how much HP.. all the details please.
I have a superchargered apex running at 10,000 to 12,000
shock wave at 90 with white spring 1 1/2 turns out. straight cut.
Blue white blue primary spring. with super tips
I'm pulling 9500 looking for 10,500 to 10.800
Hill climber not a drag racer.
Thanks again
Thanks again
What pulleys ???
HAMMER said:What pulleys ???
pullies are standard. 24-26
Load the weight from heal (pin) to toe (tip)
Try this to start:
Heal 14g (one 7 gram tungsten each side)
middle 4g (two 1 gram washers both sides)
Tip 4g (two 1 gram washers both sides)
Add or remove weight from the tip/mid to adjust to your preference.
Less weight in the tip equals more rpm and improved backshift for the mountain types.
EDIT:
Try this to start:
EDIT:
45 gram base weight ??? Standard MPI kit is 26/22 pulleys ???pullies are standard. 24-26
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
HAMMER said:Load the weight from heal (pin) to toe (tip)
Try this to start:
EDIT:
I Second That
