bluedevilblacky2k
Looking for a setup for super tips, weight location on the arms and what to put where. I have an Attak with mpi super charger running 7psi boost any help would be awesome. Thanks
Ted Jannetty
bluedevilblacky2k said:Looking for a setup for super tips, weight location on the arms and what to put where. I have an Attak with mpi super charger running 7psi boost any help would be awesome. Thanks
What part number do you have and where did you get them?
bluedevilblacky2k
Ihave the 60y set and got them from ulmer racing.
Ted Jannetty
bluedevilblacky2k said:Ihave the 60y set and got them from ulmer racing.
I am sure Allen has a very good set up for you, are you trying something different?
bluedevilblacky2k
I will check with him Friday Thanks
blurred vision
setup
Try a srx primary spring, 50/46 dalton helix on 3/3 with the pink spring. Two tungstons on the bottom and 3 or 4 washers in the middle and none on the tip. This setup is about as good as it gets, even on track dyno. Good luck
