fourload
New slides,bearings,front spring and a refresh and revalve for my shocks. Thanks cannondale for your quick, professional reasonably priced service. What a PITA the suspension is to install! Comes out in 5 min took me 2 hours to get it back in. The front arm is a bitch to get hooked in while fighting the track. Is flipping it on its side the answer?
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Get the back end as high off the ground as possible. Use some old hyfax to lay across your track, keeps your suspension above track lugs. Put front of skid in first and work the back in with some lifting of the top of the track, make sure to pull track as far back as possible. Lower the rear a little but now you can put the forks in position without to much hassle. Use a strap to compress the rear shock and lower tunnel into position, once your close you may have to tighten strap a little more to line up attachment holes. With a buddy helping you can do it this way in about 5 minutes.
marc001
- Sep 28, 2013
- Howard City MI
- 2014 Yamaha Apex SE 2017 Yamaha SideWinder LTX LE
I compress the front part of suspension with a strap and then it goes in so much easier.New slides,bearings,front spring and a refresh and revalve for my shocks. Thanks cannondale for your quick, professional reasonably priced service. What a PITA the suspension is to install! Comes out in 5 min took me 2 hours to get it back in. The front arm is a bitch to get hooked in while fighting the track. Is flipping it on its side the answer?
DennyTuna
- Jan 28, 2017
- Ohio
Good tip...thanks! Never thought about doing that.I compress the front part of suspension with a strap and then it goes in so much easier.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
For some reason my track is super tight and the install is always brutal.
I have found that if you swing the rear of the track on an angle, and take just ‘one’ side of the skid’s front arm - and get it hooked on the cross shaft. Do one side then repeat for other .
Most of the time I lay on the ground with my head to the front, I hook my foot in the back of the track by the rear rollers to stretch it. It’s like a leg press. Lol
Btw- My friends 137 goes together so much easier
Compressing the front arm with a strap or plastic tie can help. Leave the torsion springs disconnected. It’s easier to line up the rear bolt holes with the scissor flopping around.
Ms
Ms
Mototown
I have found that if you swing the rear of the track on an angle, and take just ‘one’ side of the skid’s front arm - and get it hooked on the cross shaft. Do one side then The other .
Take these silver stops out , lower tunnel to normal ride height suspension goes right in with springs in place no struggle at all.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Invest in a torsion spring tool. Have had mine since early 90's and worth its weight in gold!
DennyTuna
- Jan 28, 2017
- Ohio
We are thinking about mounting a small winch on the shop ceiling for lifting and lower the rear of the sled. For a single guy it would make this job a lot easier. We also have 4 heavy duty D rings mounted on the ceiling for hanging sled. Makes working so much easier without lifts in the way and being able to sit on a shop stool is very nice.
swampcat
YES, flipping on its side is easier for fast skid in and out. BUT, sometimes, like a track swap, laying on its side is not gonna work. Different procedures require different solutions.New slides,bearings,front spring and a refresh and revalve for my shocks. Thanks cannondale for your quick, professional reasonably priced service. What a PITA the suspension is to install! Comes out in 5 min took me 2 hours to get it back in. The front arm is a bitch to get hooked in while fighting the track. Is flipping it on its side the answer?
slimjim2525
Put a winch in ceiling. It was the best thing I ever did to work on my sleds.
Tcat100
Winch it from ceiling and collapse the front arm with a strap and it's easy
Having the skis on dollies also helps to clear the front arm. Then one side at a time hooked on bar. I collapse the rear arm sometimes. Getting the perfect height of rear is critical. A track stand won’t cut it. Need something finer like ceiling winch. Admit that it just sometimes sucks. Swear it gets easier then harder sometimes.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
As long as there is a ring or something to hook into the ceiling -a ratchet strap or strap with cam cleat works well
Ms
Ms
I have found one of the easiest ways is to have the rear of the sled suspended with a chain fall, or something similar. Then roll a floor jack under the track. With the floor jack there, the torsion springs can be unhooked and swing down so you are not fighting them. With the springs unhooked the rear can collapse.
Also, I usually back the track tensioners off, slide the rear axle forward, and tighten so it stays forward. Some models of sleds don't need the rear axle loosened and still go in relatively easy.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
It would be easier if the pro cross rear skid didn't weigh 100 lbs...
