SW 5amp accessories
Byam
En Motoneige
Canada
SW2017
custom
Where is that fuse?? Can't find it in the manuel and it is not in the fuse box!!!
I hope it is not on a 20amp handwarmer fuse!!!!
run a 12v test light off the accessory port (plugged) down by the shift solenoid/chaincase...where did you get it was a 5 amp? quite possibly its on the same circuit as the tail light since that seems high for a led tail light?
That's way different box than Viper but on Viper if accessory fuse went so did taillight and dash.
