Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
These are the hoses I was talking about earlier, was it this thread or another? During the turbo install those ports were utilized. Good find.
MCX also use all ports for vacuum in their turbo kits. But my start up and idle is not perfect anyway.
Dont go out and bother your dealers or buy tools to do this. I am experimenting and really am clueless other than having synced many carbed bikes and sleds in my day. This is a start since was suggested to do this and I am not confident in the new flash. Goal is to have a idle as smooth as a good runnin Nytro without a tuner.
Update nothing touched and mine is synchronized just fine right from factory. Maybe reason mine has always ran well? Next test is adding the hose from Nytro and disconnecting PCV.
https://www.facebook.com/steve.spiering.5/posts/1663383943687851
DT
- Dec 26, 2011
- Michigan, Flint area
- 2006 Attak
1015 Viper
Anyone know how sensitive this adjustment is? Also, how much different did your screw turns end up after adjustment; 1/8, 1/4, more, less?
-thanks
-thanks
Some more pics
This reducer had to be used because hoses were a hair to big id for bung on Throttlebody
I did NOT have to adjust anything. Never touched it was almost perfect from factory. Now I adjusted screw and it is very sensitive. 1/8 turn moves the mercury a good 1/4 in. Screws are exactly where they were.Anyone know how sensitive this adjustment is? Also, how much different did your screw turns end up after adjustment; 1/8, 1/4, more, less?
-thanks
I have invited NosPro to have his checked since it is a know bad runner without his tune. Goal is to find why these sleds vary in idle quality especially. If his turn out to be fine we need to look for another reason.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
Thanks for sharing this info! Helps a lot!
Mine wasn't in tune when I check it. The engine was to be operating temperature. And it to see where it goes when you bring it up to 3000 rpm's also.
I believe you. My fan was running and did raise rpm as much as I dared. Same result. Now to come to a conclusion I need to find a poor running one to do same test on. I also need to disconnect my PCV. If I didn't believe yours was solved by doing this I would not have taken time to do it myself. I thank you smooth ride. More to come.Mine wasn't in tune when I check it. The engine was to be operating temperature. And it to see where it goes when you bring it up to 3000 rpm's also.
I would love to see how they sync these thinks on the line when being built.
DT
- Dec 26, 2011
- 2006 Attak
1015 Viper
Thanks. Do you know how similar your 3 screw were (turns out)?
The two out side ones at about 1 turn and the centre was about 1/8. It idle like crap. Now I have the centre at 3/4 and the out side ones around 1 1/4 to 1 1/2. And it idles good now. When I had it on my sync tool the centre one was the problem when it missed at idle.
I didnt have time to run them all the way in. Will let you know in the morning. Curious myself.Thanks. Do you know how similar your 3 screw were (turns out)?
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Did you ever get the info?Is anyone know the factory set up for the 3 air idle srew on the throttle body i try to adjust whit carbtune but the result is not good want to return to factory default set up .
