Whats the verdict on synthetic oil and seafoam,I am ready to install the new oil,have new filter installed,My o3 rx1 with mc express front mount turbo has 4500 miles on it and it does use some oil.Thanks Lee
I switched to syn. Mobil1 this year but only have about 150 miles on it so far, So cant tell any diff. My sled didnt use any oil to start with but I use Mobil1 in everything I run and have good luck. Had to switch to Mobil1 in my grizz. but it was sucking oil and my dealer VETESNIK POWER SPORTS in Richland Center Wi. wouldnt do anything about it even thought its an 05 model.
Currently use Shell 0 40 Rottela synthetic the highest rated high pressure high tempature lubricant in the world designed for High boost Diesle Turbos this is as good as an oil getsfor cold climate starting and high rpm
and running hard and hot all good synthetics are better.
this sled currently 5000 miles abused from day one
while mine is currently running like total crap the oil has saved my #*$&@ more than once as if you lose your coolant or over heat your oil can help minimize any potential damage
I remember tests done in austrailia where they ran cars with no coolant for 800 miles in summer heat with no coolant using synthetic oils with no damage. coventional oils failed shortly after leaving
