Derek Fosbury
- Jan 18, 2021
- 2022 Sidewinder S-TX GT
2023 AC T-Cat EPS w/ATAC
- Sledding Location - Fenelon Falls, ON
As I posted in the 2023 Spring Surge Orders thread, it looks like I won't be one of the lucky ones to get a 2023 SRX. However, looks like I might be able to get a 2023 T-Cat.
I've scanned through old threads about the differences, but still wanted to double check to see if I understand correctly. From what I can find, the differences are:
1. different track/lug heights (1" SRX vs. 1.25" T-Cat)
2. different clutches (Yamaha durable rattler vs. not-as-durable but quiet AC ADAPT)
3. different chain cases -> or is it just the tensioner that is different? Do I still need to do the DMC Top Gear fix?
4. different gearing -> is this just from the different clutches, or is there something else that is different?
5. different skis & carbides -> although seems like carbides might be the same for 2023 with the T-Cat maybe adopting the offset dual carbides?
One question I have is around the ECU. The Yamaha site touts the "Yamaha-developed Mitsubishi ECU", but I can't find anything similar for the T-Cat. Do they have the same ECU?
Did I miss any differences?
I'm really disappointed in not getting the SRX. I really like that Team Yamaha blue. I think I'll have to find a way to cover up the purple on the T-Cat - assuming of course I'm even able to get one
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Same ECU, adapt clutch may turn out to be more durable than Yamaha. Chain case identical other than gearing, skis now look very similar. Both made in the same plant .
Derek Fosbury
- Jan 18, 2021
thanksSame ECU, adapt clutch may turn out to be more durable than Yamaha. Chain case identical other than gearing, skis now look very similar. Both made in the same plant .
Donzizrc
- Apr 1, 2022
- Illinois
- Thundercat / viper
Does anyone have the spring part numbers for the srx
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Ditto on the skis, ECU, and chain case. Until recently, the cat skis were much better. Regarding the clutch, the new adapt has been good so far. My dealer has had no issues so far. Time will tell how durable it is. I will say it is quiet and does not rattle.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
3074-380 & 3704-381, if you are referring to the rear torsion springs. I just ordered a pair for my 17 LTX. But... they are supposed to be 100-degree angle between the legs. The 3704-381 measured 101-degrees but I ordered in 2 of the the 3704-380 and they are both 108-degrees.Does anyone have the spring part numbers for the srx
Donzizrc
- Apr 1, 2022
- Illinois
Thank you
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE, Hurricane Tune on the fly
Pilot Skiis,
- Woodbridge, ON
Debating on pulling the trigger on either 2024 new LTX LE or T-Cat. Better deals on the TCat than the SRX plus I get the 1.25" lug.
Regarding the shocks, On my '17 QS3Rs I never had a problem, but I dont know if Im missing the instant adjustability.
And in firm mode electric does it match firmest setting on the QS3Rs.
Im assuming the electric shocks are better on the long rides.
Is the ATAC a mistake with 270 Hurricane tune .
Is it less of a belt blower or the same.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
The QS3Rs are night and day better than ATAC. Plus you get an infinitely better front skid shock too as opposed to the junk one that comes stock with any procross chassis. Once you setup the QS3R properly, you wont need to mess any other adjustments at all.
