T.O.R.S.
WANN4STROKE
Anchorage, Ak.
2009 Viking
2006 ApxMtn-sold
2001 MtnMax-sold
1998 VMAX 500-totalled
I was trying to put on a 2" ROX riser this weekend and set off the TORS. What do I have to do to turn it off and why did it turn on- thought there was enough cable ?
Thxs.
David :yam:
I had to disable my TORS because of the Super Charger. It wasn't hard, but for the life of me I can't remeber what I did. Once I disabled the TORS with the rerouting of the cable and a riser I felt better getting a new cable made at the local Harley shop. I reccomend a tether if u do this.
Niko,
Having never torn into one of these- is it easy to follow the cable to thenut? How much has to come off? I'll be putting Rockmeister's hand warmer kit on soon and I'll try it then.
Thxs.
David :yam:
If you want to disconnect your TORS you have to disconnect the single wire white connector and single wire black connector from themsleves then connect opposite.
In simple words,
white/black, white black, instead of white/white, black black.
You can find these wires in the bundle of wires below the dash panel right in front of the handlebars.
Hope this helps Dave!
