Dukester
I noticed I have a bulb out in one tail light. Do I pull the seat to replace or do I have to take all that rear grill work off? If its the seat, how is it attached? If the seat is off, should I be checking non related items?
Thanks Dan
Thanks Dan
Sketr2 I just checked the tail lights on my sled and yes you will need to take the seat off to replace the bulb. My seat is just sitting there ready for me to replace the seat cover. You will need to start at the exhaust cones. There are only three bolts that hold these on the one at the top and the two opposite each other on the bottom. The others are just dummies. You can then remove the bolts that hold on the rear grill. You will then need to remove the hook bolts for the seat and slide the seat back far enough to unplug the electrical connection on the right side. You can then get at the tail light. Good luck
Dukester
Thanks very much!!
Dan
Dan
Dukester
I am! We take several 4 wheelers for the prairy and one sled along just in case!!! There are a lot of years that we get snow big time at the end of Oct. My motor home is set up to carry two Harleys or 4 wheelers in a rear compartment. Here in SD you can only hunt birds in the afternoon for the first couple weeks. Plus when the birds are plentiful, we have our five limits (15 birds) in a couple hours. That leaves lots of time for other things. Yesterday we were done by 2:30. Today it may take another 15 minitues or so since five dogs will be left in the trucks. They are out of shape and can't go more than every other day. Today we will all hunt behind my two dogs. I generally can hunt my dogs for five days straight. I then give them or Me two days off before we continue the cycle.
