MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
I recently got my TD dash upgrade and the full bundle upgrade for it. Now it doesn't list the actually flash just power levels just trying to get a idea which flash and boost level is associated with these power levels
250
275
280
290
300
Was hoping one of these is the max spool 16 because here in Maine especially in certain areas I may switch back to my stock exhaust because of targeted checkpoints for exhaust checks by the Maine Warden service. I need to install the heat shields from the stock over my TD super quiet exhaust. Also some info the wardens are also measuring the exhaust outlet if its bigger than 2 and a half inches they will ticket you regardless I'm told. I know Woodys Yamaha is installing a reducer to help with this fyi. Big storm headed towards Maine next mid week let's hope it's the motherload. Ride safe everyone
250
275
280
290
300
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I might be interpreting your post wrong but it sounds like your tune package is most likely tied to the exhaust (as well as other upgrades such as BOV or Map sensor) you are/were running (Super Quiet) and you will probably need a new set of tunes to match the stock exhaust. Meaning I think Ben will need to get you a new set of SM (stock muffler) tunes including EcoTrail, PowerTrail and MaxSpool (MS) 16. Your list probably includes MS 17 and MS 20 because you have the Super Quiet exhaust. I believe MS 16 is the highest for the stock exhaust.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Jack is right. I have 2 different bundles on my flasher. One is for stock muffler, the other is for my 3" Viney Fab. You can only load one at at time into the ECU. This is the reason I got the flasher to begin with. Ran SM tunes last year and upgraded a bunch of hardware this year. Still planning on running the SM tunes sometimes depending on where I go to ride. Since you already own the bundle you would just need the flasher then let Ben know what you are trying to do so he can make the proper tunes available.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Your current options are probably
ECO Trail
Power Trail
Max 17
Max Spool 17
Max Spool 20
ECO Trail
Power Trail
Max 17
Max Spool 17
Max Spool 20
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
I was asking the same question awhile back
https://ty4stroke.com/threads/question-about-the-dash-jukebox.154934/#post-1452910
Open your app, hit arrow at top the hit the little tune button. Scroll left and right through the jukebox tunes and look at the dash at the same time. Then you can figure out what is what.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I don't think he has a flasher.
Buckeye
- Lakes Region, NH
They are right. Your loaded tune is a cai, 3 bar, bov, mod exhaust jukebox. You will need to flash the ecu with SM 16 tune jukebox which is easy if you have a flasher. Otherwise it’ss pain in the butt.I don't think he has a flasher.
MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
Yeah I don't have the flasher but had the dealer flash it with the dash upgrade so next time I'm there I'll set that up or at some point I'll grab a flasher. Thanks guys
Buckeye
- Lakes Region, NH
The problem is that you cannot run both jukeboxes at the same time. You will need a reflash each time you change mufflers. Thus the need for a flasher.
