IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
I have 6 HP numbers that I can scroll through on my dash to choose from.
250
275
280
290
295
300
Are these tunes separate from what I have downloaded on my flasher.
Like I have ecotrail,powertrail, Max pump 17 and 20
Reason I ask is because I also have Max 17 lean on my flasher memory and that is not supposed to be used if you have an aftermarket BOV, which I do.
So before the dash cluster flash I just never loaded that one into the sled.
But if now that Max Lean 17 is somewhere in those numbers above 250-300 loaded onto my dash now, I do not want to accidentally choose that one. Dash only shows HP numbers and no name of the actual tune?? Confused...
Thanks....
250
275
280
290
295
300
Thanks....
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
If you call Mike or Ben at TD they'll answer your question.
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
He's sick and busy..
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
How confusing can they make it?!
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Open your app, hit arrow at top the hit the little tune button. Scroll left and right through the jukebox tunes and look at the dash at the same time. Then you can figure out what is what.I have 6 HP numbers that I can scroll through on my dash to choose from.
250
275
280
290
295
300
Thanks....
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
Thank you. I will try that.Open your app, hit arrow at top the hit the little tune button. Scroll left and right through the jukebox tunes and look at the dash at the same time. Then you can figure out what is what.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I only have 5 in my Jukebox. I have 3 bar, bov and a 3in exhaust. You might have the wrong jukebox.
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
Well that worked except it showed me I have two 290 tunes.Open your app, hit arrow at top the hit the little tune button. Scroll left and right through the jukebox tunes and look at the dash at the same time. Then you can figure out what is what.
One is Max spool 17 and one is the Max 17 lean im not supposed to use.
App shows the name, but dash just shows me 290 twice then on to 295, 300 and back to 250 and up.
Im screwed. Gotta call I guess
Was hoping this was simple.
Thanks for the help..
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I feel sure they can clean the tune list. Interesting my flasher now has a 900T Tune on it.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
So does mine.I feel sure they can clean the tune list. Interning my flasher now has a 900T Tune on it.
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
Called TD and supposedly they are going to get back to me. I just want that Max 17 lean out so I don't accidentally use it.
I have in my Jukebox 7 tunes:
250 Ecotrail V2
275 Powertrail CAI V5d
280 Max 17 V5
290 Max Spool 17 V5
290 Max 17 Lean V5
295 Max Spool 19 V5
300 Max Spool 20 V5d
I've got :
Dalton weights
Cold Air Intake
3 bar sensor
Turbosmart BOV
Up-graded fuel pump
Hurricane trail muffler
250 Ecotrail V2
280 Max 17 V5
290 Max Spool 17 V5
290 Max 17 Lean V5
295 Max Spool 19 V5
I've got :
Dalton weights
Cold Air Intake
3 bar sensor
Turbosmart BOV
Up-graded fuel pump
actionjack
- Apr 9, 2005
This brings up a good question for GAP. Can you select a specific set of Tunes from the available list and only flash them, rather than all files?Called TD and supposedly they are going to get back to me. I just want that Max 17 lean out so I don't accidentally use it.
250 Ecotrail V2
280 Max 17 V5
290 Max Spool 17 V5
290 Max 17 Lean V5
295 Max Spool 19 V5
I've got :
Dalton weights
Cold Air Intake
3 bar sensor
Turbosmart BOV
Up-graded fuel pump
- 9K
- 18K
