snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
You need to update your tune.
Yep TD has a header-specific version of the MS 17 tune.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Looks like an upgrade coming then. Thanks.You need to update your tune.
Fleecer
- Jun 13, 2014
- 2019 SRX
Okay thanks! I guess I need a education on tunes and this 3 bar stuff. I usually hang out in one bar! Lol. So what does the 3 bar do? Thanks Jeff.
Here is my 5 cents....
Factory 2 bar sensor only allows ecu to read up to 16.9 lbs boost, so OK for Powertrail, and Max 17, but the bigger tunes require 3 bar, and is a must for MS17, MS20, Race tunes etc.
The bigger fuel pump allows you to run lower octane, and I highly recommend it if running MS17 or higher. Otherwise, you will have to mix race fuel/octane boost, which gets old fast. With the big pump/3 bar, you can safely trail ride MS17 on 91 octane, pending that is what actually came out of the pump.
IMO, Max17 not much different than PT and not worth it. MS17 is much more violent, and the extra $325 in auxillary hardware is worth the price of admission, but you need good 91. On good 91, you can operate MS17 without issue, but if racing back to back long pulls WOT in excess of a mile in length you would need 93 octane to keep the knock light at bay, especially if conditions are mealy/parasitic.
MS17 can be run with a header, but since the header flows more, boost will drop a pound or 2. Upgrading to MS17 Header Tune will restore the 1-2 lbs of boost the header loses due to flow and will bump up power and speed. In my circle of acquaintances, the guys with headers are faster than the guys without. Be advised, you can run MS17 with a header, you CAN NOT run MS17 Header Tune with stock manifold. It will overboost, and could cause damage.
The header also allows more power with less octane, hence you are less prone to knock on those long, drawn out, World War 3, knock down, drag out races, when you need to annihilate 3-4 people in a row, back to back!! Yes, the header is pricey, but if you absolutely, positively, unequivocally, without a doubt have to be the KING, it's the price of admission.
That being said, if you arent a racer, and you want a reliable tune that is strong, cheap, reliable, and will run on 87 octane without issue, Powertrail is hard to beat.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
290 is Max Spool 17 without header or fuel pump. Max Spool 17 with header/fuel pump is 305. TD came out with header-specific tunes this year. Just so you know, the hp numbers we/they use to identify the tunes is becoming less relevant because TD adjusts the tune for each variable (e.g., header v. no header, stock fuel pump v. upgraded pump, 3-bar v. stock 2-bar, etc.). I view this as a good thing. They're constantly fine-tuning their tunes and making them variable-specific.
Good info, now that I have confidence in my clutch and belt (xs825)set up, I am thinking of the next step up from my Max Spool 16 tune, and this 290 hp tune with it's cheaper upgrade costs have me itching for a bit more hp!
So which TD muffler is needed to achieve the full 290 hp with the MS 17 tune?
She’s been tough tested again this year with nothing but primary roller wear! This thing sees 120 and over, many many times daily, and the xs825 still looks new. It does take different clutch settings then the JP, but it is tough!
2 weeks in a row, it got tested many times on the County Trails, and passed with flying Blue colors! Ha Ha.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
View attachment 160939 View attachment 160940
I do have the 3 bar and BOV already, so from what I read from some here, the bigger pump may not be needed? Or is it?
Which exhaust for the 290?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
You don't need the pump for the MS17 290 tune.I do have the 3 bar and BOV already, so from what I read from some here, the bigger pump may not be needed? Or is it?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for the reply!
Impressive speeds with your set up. That 1” track rolls faster.
what exhaust are you using on your 290 MS 17 tune?
DMCTurbo
- Nov 12, 2005
Thanks... I'm running an MBRP race exhaust. Sounds wicked but moving up to a 3" next year.Thanks for the reply!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Such a great thread for those of us wanting a bit more, and the info gained from all really helps in understanding, prior to talking to, and ordering from TD!
Thanks All!
Thanks All!
If I remember correctly, Ben recommends 91 for powertrail. Ecotrail is the only one claimed safe for 87.Here is my 5 cents....
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Ecotrail with a Smm was my first tune, and it was cool running 87 on that! And I had many long pulls to. That was a Woodys (Dealer)thing along with a TD tune back then!
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
The upgraded fuel pump is always a good option when you get to 17+ for boost. Especially with any kind of miles on the sled.
Fleecer
- Jun 13, 2014
- 2019 SRX
If you plan on riding the County Trails on MS17, the big pump is an absolute necessity. Even with the big pump, if you give her the beans, those back to back long stretches will requure good fuel.
The 2.5 SQ is one hell of a muffler, and I have yet to hear anything quieter than flows more! Anything other than the 2.5 SQ will guarantee you a ticket in Maine, and still, you are rolling the dice.
sledding rocks
- Feb 11, 2017
- north
- sidewinder
I recommend td 3inch or sandle 3inch both great exhaustThanks... I'm running an MBRP race exhaust. Sounds wicked but moving up to a 3" next year.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
And the price diff between a stock fuel pump $389 and the TD larger capacity fuel pump$140 makes it a good deal too.
I have been extremely fortunate with my smm with no tickets, but it is only louder at idle. I really prefer the sound of the stock muffler whereas with the stock muffler you can hear the note of the revs, but with my and other mufflers, it sounds as if they have no revs. Know what I mean?
Again, thanks for that info and I was wondering about that one. I hear that it needs re packing after a couple of seasons?
I see he also has 2 smm, one claims 10hp, and the super smm claims 20hp.
Yep we ride the county at every season’s end, and have been since late 80’s, I would say. Whether playing or working in the county, I’ve had nothing but positive experiences with all the great people and friends that make it their home!
I, or others that I ride with have learned, no sled is bigger then those county trails!
Edit: 80’s not 70’s.
