temp gauge mount
Daranello
Suspended
Sudbury, Ontario
I have a round digital gauge that I would like to mount. Any sugestions or were I could buy a mount?
I think mounting it to your riser is a pretty cool way of doing it. That way all the wiring can go down through the loom with the rest of it. Plus you won't have it always staring at you distracting you from the stock pod. If the brightness levels are different it can be distracting. Plus your only going to be concerned about the temp durning certain situations. It's not like you going to constantly watch you temp. I think either side of the riser would work just have to play with it. I can tell you that it will fit nicely between the 5" pivioting Rox riser.
I made mine out of a plastic cutting board from Walmart for $3. Just cut it to the shape you want it.
I cut a hole in the lower right side of my dash with a 2 1/2 inch hole saw.
I mounted mine above the speedo. It's in a pod
