Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Timebomb I did some trading with Aaron Excell before the kit was ready, I had something he wanted 8)
Beast, it's not a valve but a T; aluminum pipe with an adapter welded on where you can screw in the sending unit.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
OK mighty now i feel better,i do like the gage,but its to bad yammi did not do it for us,like poo did on there confusions,as there gage package is second to none,the apex looks nicer,but does not display near as much info.MightyWarrior said:Timebomb I did some trading with Aaron Excell before the kit was ready, I had something he wanted 8)
Ride-N-Rice
Just a thought, take a small piece of clear hose that will fit inline just for a test, silicone a piece of dark fish line or something like it to the inside wall of the hose and fire the motor, which ever way the line goes is your flow.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
A few guys PM'ed me asking if the bracket was painted; No it's polished to a mirror finish. If you look close to the 1st pic you can see my reflection as I took the pic
Like the install Mighty. Now a couple of questios. What is normal operating temp? And what temp. does the "horrible" yellow light come on at?
byoffcr
Mighty W nice install..
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Mother nature isn't helping out with snow so I was only able to ride around for a short while last weekend but temps were holding at 180. I let her idle for an extended time in an attempt to see what temp triggered the light. No go, she rose to about 200 and stayed, no light. I did notice that the fan was triggered at about 190-195.fatchance said:Like the install Mighty. Now a couple of questios. What is normal operating temp? And what temp. does the "horrible" yellow light come on at?
Got a reply from NY Warrior and says the light comes on at 210 with his warrior. I just wonder if we are doing alot of worrying about the running temps for nothing. It's such a small temp window. Usually I can get enough snow on the side of the trail with one blurp of the throttle to get the light to go off. I still like the install though it looks trick.
