- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
1crazysledder, I'll try to get a picture of the blue backlighting in the dark. The gauge is very readable as you're riding and doesn't move alot if you're in the same snow conditions all the time. The pod that BPE made for the RX-1 will be available for the Apex in a couple of weeks. They are just getting started on the prototype and will have to make a mold and should have a finished product available in roughly a month.
y_guy
- Feb 22, 2005
another stupid question, but why would you need one of these if you are riding on snow.
Tork
y_guy said:another stupid question, but why would you need one of these if you are riding on snow.
With the new radiator I doubt you would need it to monitor overheating, but guys may want to use them for warm-up to know when to go full throttle. IMHO you dont have to have this but if is a cool accessory.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Purely added safety. I like to be able to look at a guage and know exactly what temp the coolant is and not have to worry if the overheat light or radiator fan may have malfunctioned.
- Apr 14, 2003
- Hessel, Michigan
I had one on my sled, and saw when trhe temp was going up on trails where the snow is like small pellets. The temp rose up to 200°
I could drag my feet and cool it down right away.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Srxspec said:1crazysledder, I'll try to get a picture of the blue backlighting in the dark. The gauge is very readable as you're riding and doesn't move alot if you're in the same snow conditions all the time. The pod that BPE made for the RX-1 will be available for the Apex in a couple of weeks. They are just getting started on the prototype and will have to make a mold and should have a finished product available in roughly a month.
Kool. I'll check back in about month with you. I'm really not to crazy about digital guages, but I may get one for my sled. It seems to be small enough. Not to bad priced either.
1CS
SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
I like to know when the sled is warmed up.. Don't like to take off other than to get it out the trailer till its warm.
Sodes
- Nov 8, 2004
- Elmhurst, Illinois
- www.sledovations.com
Temperature Gauge
I'm in the process of completeing my water temp gauge install (see attached). I will be putting into a kit with a rear heat exchanger.
Sodes
Sodes
Any news on a group buy yet?
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
- lacroixmotorsports.tripod.com
Who sells that rear heat exchanger
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
You shouldn't need a rear heat exchanger... The radator took care of these problems...
Sodes
- Nov 8, 2004
Water Temp Kit
I'm putting together a gauge kit that includes:
Dash Template
100 -250 White Face Electronic Water Temprature Gauge
Rubber Mounting Boot, floats gauge to avoid shock damage
Wire Harness, with directions to tie into OEM Electrical
Inline Hose adapter, machine billet aluminum
$160 plus shipping
Sodes
Dash Template
$160 plus shipping
Sodes
- Apr 17, 2003
- Menno, SD
- Menno, SD
Sodes, that guage is going to be tough to mount in an Apex dash.
Everyone else I have pictures of the guage installed in an Apex, I will post them later tonight!
- Apr 17, 2003
- Menno, SD
- Menno, SD
