I'm looking for the size of the coolant hose so I can add a hose adapter with temp sensor. I found a nice inexpensive setup on Amazon from Koso. Sensor adaptor plus thermometer is only $66.
http://www.amazon.com/Koso-America-..._UL160_SR160,160_&refRID=0NYAXCN046TMPH0EM79V
Tavon
- Dec 10, 2015
- Iowa
- Nytro
Pretty sure you will need a 26mm adapter . Wish I had seen this link a few weeks back! I paid twice that for an uglier gauge!
thank you! With that said, I guess this would be the correct adapter with gauge. Can someone please verify if this will fit? I know Tavon says "pretty sure" so before I spend the money......
http://www.amazon.com/Koso-America-..._UL160_SR160,160_&refRID=0X3RH2A4GW9PDNQV7DZ0
http://www.amazon.com/Koso-BA024B11...263_img_2?ie=UTF8&refRID=16PCC6Q756KD16VCRGKB
Mountaintech
Put the sensor here instead. Much cleaner install without hacking up a hose. Drill out and tap the blind hole shown.
radianguy
- Jan 1, 2007
I have that setup, works great!I'm looking for the size of the coolant hose so I can add a hose adapter with temp sensor. I found a nice inexpensive setup on Amazon from Koso. Sensor adaptor plus thermometer is only $66.
http://www.amazon.com/Koso-America-Temperature-Sensor-Adapters/dp/B002LGUKQU/ref=pd_sim_sbs_263_7?ie=UTF8&dpID=41sxIEmqy8L&dpSrc=sims&preST=_AC_UL160_SR160,160_&refRID=0NYAXCN046TMPH0EM79V
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
26mm is the size, you can get away with 24 mm and still get a good seal. The way mountaintech shows is also another way. I did mine that way and when I did the wife's sled I used the adapter. Both ways work. You will like the gauge , it can be a little hard to read when the sun is directly shining on it but other then that they are great.
Tavon
- Dec 10, 2015
- Iowa
- Nytro
what size is the hole/tap? I'll need to buy new and don't' want to buy more than I need
Mountaintech
1/4" NPT
