Jasonjmccoy
- Mar 22, 2019
- Plymouth, WI
- 2012 Nytro XTX
Any one got any tricks for running their sleds with the fuel tank off in order to test exhaust and such? Is it is simple as a length of spare fuel line? What about the electrical connections?
YukonMP
- Dec 25, 2014
- Yukon Territory
I expect it is more practical to run with the tank loose and set to the side. If that gives you the room you want I'm sure it is the easiest.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
What he said. There are two lines and the electrical connections to deal with. And the pressure line has a special connector.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
on the Apex you can reroute the lines and wires around the frame and put tank on a table right beside the sled and still hook them up. I don't know on other sleds.
Pstn head
I thought you just covered the equast pipes and if it doesn't stall you have a leak, or something like that ?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
if it is a big enough leak. you can have a small leak and it will still stall.
Pstn head
Ohhif it is a big enough leak. you can have a small leak and it will still stall.
Dr. FeeLGooD
On my Nytro I could set the tank on a stool beside the sled with the back end facing the sled with lines still attached. I would do this with only a gallon or two of gas in it.
Jasonjmccoy
- Mar 22, 2019
- Plymouth, WI
- 2012 Nytro XTX
cool, thanks, I'll give it a try
- 10K
