Clamb
- Oct 2, 2016
- Peoria IL
- 02 Sx viper Er 15 sr viper xtx
- Peoria il
I’m trying to release a stubborn threaded collar on the wobble bearing and it’s giving me fits.I have already damaged it or I would try and thread the nut back on to beat on but can’t at this point. I’m going to try and heat it tomorrow and see if it will release. Wondering if anybody has any other tips or tricks for me. I’ve read everything in the facts many times on this just can’t keep hitting it it’s driving me
DTJ
- Mar 31, 2016
- Brainerd, MN
- 2023 Yamaha Sidewinder XTX
2017 Yamaha Sidewinder BTX
I had same problem, ended up using a puller on the other side and pulled the bearing and arm housing off the shaft together and then pulled shaft out thru chain case.
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
dang thats what i figured someone would say. did the wobble bearing come out with the collar and shaft then?
Yes and then you cut it off.
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Thanks guys had to pick up a new bearing pulled but it’s out and bearing was definitely toast. View attachment 150710
How many miles on the original?
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
6400 and some change. Just about to reassemble the chain case and noticed a ball was real lose and ground flat on one sideHow many miles on the original?
yamahaguy
Ride SAFE
- Apr 20, 2014
I have mine all apart now and wobble bearing seams ok at 4600 miles but upper chain gear inner bushing shot. I'm getting a new upper gear
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
Got a pick. I’ve read about about people saying this I think mines ok everything meshes ok but curious as to were the bad spot on these are.
If the bushing is copper colored its shot.Got a pick. I’ve read about about people saying this I think mines ok everything meshes ok but curious as to were the bad spot on these are.
