Clayton
- Dec 22, 2019
- Rock creek
- 2016 Sr viper mtx 153
We bought a 2009 fx nytro mtx last year and it has a problem with the throttle when you turn left the throttle opens up half way the check engine light is on also does anyone else have this problem?
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Check cable routing. Sounds like it is getting pulled tight when you turn!!
Yes, what 03 said and if it has a riser that will often cause it.
Clayton
- Dec 22, 2019
- Rock creek
What about the engine light being on
Could it be a sensor?
Any codes showing on dash?
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
I honestly forgot exactly what tors reads, but I bet if the throttle lever was at idle and the rpm went up, it would throw a light/code and a throttle cable being pulled couldn't get any easier to see
Think it is 84I honestly forgot exactly what tors reads, but I bet if the throttle lever was at idle and the rpm went up, it would throw a light/code
