**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
good call t bone...i kept looking at it knowing it was wrong...couldnt figure it out...now I see it tightened it up considerably going over the pad....
zedosix
Ok, so I will need to disconnect at the throttle and re-locate under the pad and up the right side. Right?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
no...first try removing the crashpad...then pull to the right side...then reinstall the crashpad so the cable comes out underneath !
zedosix
sj said:no...first try removing the crashpad...then pull to the right side...then reinstall the crashpad so the cable comes out underneath !
Done. It still seems very tight and the pad just doesn't sit level. I wish to see a shot of how it should look. Anyone?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
just went out to check mine...routed in front of crash pad...goes to the left as well..
if your sled had the handwarmer update...probably got routed a little off...if its still tight in front of...I would loosen the throttle adjuster and back it off..
zedosix
sj said:just went out to check mine...routed in front of crash pad...goes to the left as well..
Its an 07 so I thought the handwarmers were taken care of at factory. There was no problem with the warmers. Here is how I have it running now. I'll give it a try tomorrow on the stand.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
see the cable resting on the riser stud...try to manipulate it so its not on but in front of ?
zedosix
Works well now, the pad is a little cock eyed but hey, no stalling.
