Throttle problems
good call t bone...i kept looking at it knowing it was wrong...couldnt figure it out...now I see it tightened it up considerably going over the pad....
Ok, so I will need to disconnect at the throttle and re-locate under the pad and up the right side. Right?
no...first try removing the crashpad...then pull to the right side...then reinstall the crashpad so the cable comes out underneath !
Done. It still seems very tight and the pad just doesn't sit level. I wish to see a shot of how it should look. Anyone?
just went out to check mine...routed in front of crash pad...goes to the left as well..
if your sled had the handwarmer update...probably got routed a little off...if its still tight in front of...I would loosen the throttle adjuster and back it off..
Its an 07 so I thought the handwarmers were taken care of at factory. There was no problem with the warmers. Here is how I have it running now. I'll give it a try tomorrow on the stand.
see the cable resting on the riser stud...try to manipulate it so its not on but in front of ?
