snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I am in the process of studding my sled and was looking for ways to make it a little easier. Normally I just use a cordless drill and a track drill tool. (http://www.cbperformanceparts.com/studs-and-backers/woodys-track-drill/)
A typical cordless drill has an RPM of 1,800-2,000. I decided to buy an air drill which spins at 22,000 rpm to cut through the cords quicker. I'll never go back to a normal drill.
It heats up almost instantly and probably cuts the time to drill by 50-75%.
https://www.amazon.com/gp/product/B017W2PINC/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
My next problem was the quiet lugs. I know some say the stud will just suck down, but I didn't like the way the would sit once installed. I found a cutter with a replaceable center guide that works perfect to cut the quiet lug down. I made a piece to center the cutter the same size as the stud hole and then ground off the teeth that protrude higher than the main cutter blades as they won't be needed in this case. (It is made for wood) It works perfect to cut the lugs flush with the track so I can stud like normal. (Just be careful not to cut too deep)
https://www.amazon.com/Irwin-Indust...TF8&qid=1492606469&sr=8-36&keywords=1"+cutter
Anyway... Just thought it could help others when they go to stud. Let me know if you have any questions!
