srx70024
Speedo pickup replacement
Just a thought here...
If you grind off a tooth or two from the speedo pickup and you don't like the results, they are only $11.00 for a new one.
I too am going to try grinding off a tooth, but am awaiting results from others.
![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
black john
gear
cutting two teeth of the rx 1 worked got the speedo with in 1-2 mph the odmeter went out after but i did not care. allso putting 10 tooth drvers on did the same thing with the stk gear but its a lot more work and money as you have to change gearing 1 down on the top and two up on the lower gear
legend
can anybody show a picture what you are grinding off thanks ![Yrules :yam: :yam:](/styles/default/xenforo/smilies/yrules.gif)
srx70024
Have a look at this thread. It should answer all your questions.
http://www.ty4stroke.com/viewtopic.php? ... peedo+gear
try this one.... ??
try this one.... ??
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
srx70024 said:Have a look at this thread. It should answer all your questions.
http://www.ty4stroke.com/viewtopic.phpt ... c&start=15
404 error.
- 40K
