YamaHank
- Apr 1, 2013
- Boston, MA
- 2018 SR Viper RTX
So I had to adjust my chain tensioner 6 full turns after 35 miles. I also had to go to the local cat dealer for my new exhaust gasket and took the liberty to buy all of the ones they'd had in stock....(sorry xf7000 owners)
Anyone know the proper torque spec on the three bolts that hold the header to the can?
09nytro
Wow! 6 turns that's a lot are you going finger lightly seated then back off 1/4 turn , you may have compressed the spring on the adjuster inside the case .
With 6 turns it seems like the chain would have been jumping !
stingray719
09nytro said:Wow! 6 turns that's a lot are you going finger lightly seated then back off 1/4 turn , you may have compressed the spring on the adjuster inside the case .
Agreed, just finger tight then out at least one turn. I like to rock the secondary clutch to watch slack and see how it is and where I am going with adjustment just in case.
YamaHank
- Apr 1, 2013
- Boston, MA
- 2018 SR Viper RTX
Finger tightened 6 full turns and backed off 1/4 turn and tighten the nut up.
Yes, the sled felt like it was taking a second to go after I hit the throttle...hoping this fixes the problem.
fxnytroxtx
Guest
Mine was also about 6 turns, so was couple of other members on here.
