dan wilson
- Jan 20, 2009
good morning guys,having a issue with my wifes 06 vector gt,running great,carbs synced,cleaned and idle's great,if you run it easy no problem,when you start to hammer it hard it will set off the tors,it will back fire and set flash the code 84 only for a few seconds,and if you shut it off and restart,drive bearing looks ok,slack in throttle ok,just does this when you come out of the throttle hard at corners or stop sign,s,I am going to test the switchs in the throttle and on the carbs tonight,checked battery out put is with in spec,new fuel,looking for something that we are missing,I am ready to by pass,driving me crazy,put it's a safety feature I want to keep working on the wifes sled
theCATman
- Feb 19, 2007
- WI
- Yamaha
Put a tether on it & bypass the POS TORS system.
Is the speedo working or seem to be working correctly? My old '06 Nytro had a TORS issue & it was the speedo sensor not reading correct.
metalman2
- Dec 23, 2013
I'd check your bearing on the speed sensor side. Mine started coding when the bearing went out. Do you feel a vibration when you back off the throttle at all?
tommyt5078
My speed sensor went............got code 42 first and then code 84!!!!!
dan wilson
- Jan 20, 2009
I am going to check the bearing behind speed spenser tonight,I grease it every 500-600 miles,going to clean tps sensor also,someone could be plugs going bad also,if I cant get it figured out by this weekend,i will bypass until I figure it out
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Check your throttle cable free play. You may have it just at the point where it works fine when riding easy but not quite enough clearance when you push the sled. The switch in the throttle block must be engaged before the carb opens.
michmobiler
Maybe check the condition and routing of the throttle cable too.....if you let off the throttle quickly and then pin it again this can happen. I know as I've been there!
Also be VERY careful about bypassing the TORS! Had a friend bypass his and the throttle stuck wide open and the sled, minus rider hit a tree!
dan wilson
- Jan 20, 2009
checked drive bearing behind speed senser,all good,checked throttle cable,all good,so we started checking ohms to throttle and tps,found the problem,tps sensor,is bad,way out of spec!checking on a tps,are they cleanable? or just replace?thanks for the help
