How do you bypass the kill switch on the handle bar. Put a new throttle on and need to bypass the kill switch because it is part of the tors system. Any one ever did this before? Its on my asphalt sled 04 Rx warrior.
Yamadog
Yeah you just jumper the 2 wires at the conection unbder the handlebar pad and take the kill switch out of the series. I Believe it is the only 2 wire contection on the right side of the bars.
Hey Thanks I finally figured it out, I took the controls completely off so I looped it in the harness. Thanks again
wienerwater
Thats what I was going to suggest, but a little confused when the wires under the handlebar pad came into the equation.
