srvfan
- Nov 9, 2004
Is there an easy trick to removing the rear torsion blocks without having to remove the rear skid ?
thanx.
thanx.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
If you mean the adjusters yes! Just release the spring from the slide rails by carefully removing the bolt while keeping tension off it. Spring isn't terribly strong down there
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
X-2If you mean the adjusters yes! Just release the spring from the slide rails by carefully removing the bolt while keeping tension off it. Spring isn't terribly strong down there
While off grind off the top of the loop. You then wont have to remove it anymore and with RTX there is a wheel in the way also. SwampCat told me this many miles and years ago. Thank him everytime I have to remove skid. The loop part is only for racing to keep spring on perch when a ski gets stuffed into it. If that happens trailriding is bigger issues to worry about than spring coming off!
raptordan
- Jul 5, 2004
- Barrie ont.
- 2017 sidewinder ltx le
I've done this to all my sleds over the years , great little mod and makes removing and installing skid SO much easierWhile off grind off the top of the loop. You then wont have to remove it anymore and with RTX there is a wheel in the way also. SwampCat told me this many miles and years ago. Thank him everytime I have to remove skid. The loop part is only for racing to keep spring on perch when a ski gets stuffed into it. If that happens trailriding is bigger issues to worry about than spring coming off!
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I never take mine off, I always almost break a finger or knuckle screwing with them!
Thats preseason training! Need that hand and arm strength to hang on. With the loop ground I usually will just use a hammer handle to guide the long end of spring into the slot.I never take mine off, I always almost break a finger or knuckle screwing with them!
