schwaaa31
- Aug 31, 2014
- 2009 Nytro
I'd be interested in a pair...
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
IIRC, the preload adjuster is the same across all Yamaha models. I got some sets for our sleds which have 5 settings. Basically a pentagon. They work great. Made of black anodized aluminum. No longer available.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
I would be interested in a set for my 08 Nytro.
Nytro-glycerin
- Dec 13, 2014
- 2010 Nytro XTX Black edition
Count me in for a set. Been looking for some to purchase. Keep us posted please.
dennyboy
- Oct 4, 2013
- Minnesota
- 2012 nytro XTX 1998 srx 600
i would buy a set for sure allways could use some more better adjust ability.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Been working on this and here's what I've come up with. Position 1 and 2 will be same as the stock M and H settings. Position 3 would be 1.5 times more preload than H and position 4 would be double the preload of stock position H.
Main 1/2" thick block will have a plate riveted on each side to keep spring in place. Material will be 6061 Aluminum. I can get all pieces burned out and require no machining or welding....which will allow me to offer these at a better price. Material would be 6061 Aluminum
To rotate the block, a 1/4" ratchet drive can be inserted into one of the 4 square holes. Once I do a test fit up I may opt for a 3/8" holes if the 1/4" ratchet does not provide enough leverage to turn the block.
This design allows me to get all pieces burned out and require no machining or welding....which will allow me to offer these at a better price. Will post up pricing soon once I hear back from from shop that does all my plate burning.
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
Sounds good man , I want them !!
Sent from my SCH-R950 using Tapatalk
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Nice Travis. Glad you left the first 2 positions stock. Put me in for a set as well.
Pete
Pete
Sledboy
Count me in too!
Bog
- Nov 8, 2015
- Yorkton, Saskatchewan
- 2014 nytro
Yup me too
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Got some pricing back. Thinking retail will be around $80 a pair. Will update this thread once I get my prototype set to test fit. Hopefully by next week.
dennyboy
- Oct 4, 2013
- Minnesota
I can't wait!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
4 position block didn't suit me. Too big of a jump between stiffer settings and nearly impossible to adjust.
Drew up a 5 position with stock 3 and two firmer clicks. 5th position is 1.5. Times stock H setting.
dennyboy
- Oct 4, 2013
- Minnesota
Sounds good
Northern
- Nov 18, 2015
- Whitehorse YK
- 08 Nytro
08 Phazer
I am interested and following.
