TPS and diagnostic mode
TD Max
Central WI/Hazelhurst WI
2015 RTX LE 145 miles latest ECM programming from new.
I've been reading about people checking TPS and only seeing 80% at WOT so I figured I would check mine. Key on engine off press and hold both lower buttons on the dash until the screen changes. Use left down to bring up Diag then right button to select. This will bring up TPS
Engine at full operating temp
TPS relaxed .6v and 0%
TPS pinned 3.9v and wants to bounce between 100% and 127% depending how hard you squeeze. Nothing in between. Voltage does not change, but I can only assume that it is changing ever so slightly in the hundredths position that does not display?
Not sure if I need to adjust the TPS back a bit or if anything at or over 100% uses the same maps?
What is the proper voltage spec range for idle position?
I have not seen ant information that states the tps should be set using the sled gauge.
Everything i have read clearly states to use the inline diagnostic tool (catt2 for cat not sure what yamaha calls theirs)
While i know the method you are currently using has been used on yamahas in the past it is not the prefered way according to what i have read.
Maybe thats why it seems wrong???
Could be
The 80% talk is on FB and I really don't care for that discussion format. One thing that I do wonder is if the low readings may be part of the cold protect mode?
For the moment I'm going to assume that this is just a case of too much information and nothing is wrong with mine so it can remain as is.
I read the 80% somewhere else. Maybe on the cat forum of HCS. I do lnow that if you search hcs someone made thier own tool to test the tps. Not sure exactly how it worked but if you have free time its worth a search.
I agree about the whole too much info. I believe the system is just unfamiliar to most people and people want to help/post what they know from previous tps experiences and maybe just maybe that knowledge does not apply perfectly to this situation?
Just out of curiosity, why are you looking at the tps? Are you having a problem? Or areyou like me and just cant leave anything alone? Lol
DO NOT adjust your idle screw or TPS, if it is out of range take to the dealer. This is not a user adjustment you want to make in my opinion.
But gee guys if it goes to 127% now I wonder what it would do at 150% ;)
Definitely one of those TMI things, but it is strange. Seriously though I'll check it cold and see what it does just for grins.
Are guys opening the throttle slowly or jamming it open. It should be slow for correct readings and to see dead spots. I don't know how accurate the diag display is compared to plugging it in.
Subaru2006
My RTX reads 3.8v - 98%, my XTX reads 3.9v - 100%. Both of these reading were with the engine cold.
Before the ECU update the RTX would read 80% so either my dealer adjusted it or the update changed something.
In seeing the same thing 80% before update, checked today after reflash and now shows 99% at wot cold, something changed.
I checked mine it was 80%. But the sled only ran onto the truck. I spent a few hours on it today, so I will check again. 0.6 0% & 3.8 80% cold after flash but limited running.
2014 viper, mpi
2009 Phazer 144"
2015 SR Viper MTX 153" (Standard black model)
Relaxed = 0.6 volts & 0%
WOT = 3.8 volts & 100%
Hello Mike!
I'm afraid it should hit 99 ~ 100% ....... I would have it looked at by a dealer.
Regards,
Scott
cid:_1_104AAED8104AAAD80060360185257DCB
YAMAHA MOTOR CANADA LTD.
480 Gordon Baker Road, Toronto, Ontario, M2H3B4
T 416-498-1911www.yamaha-motor.ca
This message is intended only for the named recipients. This message may contain privileged, and/or confidential information. If you have received this message in error, please destroy it and notify the sender.
Ce courriel s'adresse exclusivement à son destinataire et peut contenir des renseignements confidentiels ou privilégiés. Si vous n'êtes pas le destinataire prévu, veuillez signaler toute erreur de communication à l’auteur par retour du courrier et supprimer tous les exemplaires de ce courriel.
To: ymcacr@yamaha-motor.ca
Date: 10/01/2015 10:37 AM
Subject: Yamaha Motor :: Contact Us :: Mike Fowlow
cid:_2_102BB0D0102BACD00060360185257DCB
cid:_2_102BB820102BB4200060360185257DCB
firstname: Mike
lastname:
Fowlow
email:
fowlowman@hotmail.com
telephone:
Telephone
productmodel:
2014 viper xtx
v
Find a dealer
