Blue Me
Do the cogs need to be changed to go to the new RipSaw 1.25" track? I ahd heard that the wheels may need to be smaller. I plan on studding it with 144 1.325 studs do I need to do anything else??
NO change is required to get a 1.25 track in.
MUSTANG1
- Oct 6, 2005
- Canton, MI
- 2016 VIPER L-TX-LE BLUE
Test drive the new ripsaw before you stud, you'll be amazed at how much it grabs without studs!
Blue Me
Most Ripsaw tracks that I have seen with out studs have had torn off lugs and also with Simmons skis and having 4 - 6" cutters around the horn I am pretty certain I am gonna need to push these skis with a bit more intensity. SO Tom you say I can stud it also huh? I really wanna use the same StudBoy's I put in my Attak the 1.375 (same size as Woody's) So nothing more than just a plain old track change is that what I am hearing here??MUSTANG1 said:Test drive the new ripsaw before you stud, you'll be amazed at how much it grabs without studs!
