ReX
Last season there were many posts about people loosing track clips on their Apex sleds.
I commented that I'd never lost a single clip ever, nor had any of my buddies. In total we had well over 50,000 kms worth of riding on Apex sleds.
Today I checked over my 2007 RTX and to my surprise I'm missing or have broken 11 clips.
On top of that there are at least another 10 that are loose and 1 that I was able to remove with my hand.
Its split about equally between flat and guide clips and about half of the guide clips are not actually missing, but they are missing just the guide.
Looking at the clips carefully I can see that it is the leading edge that has loosened off almost as if the clips were hitting something or dragging hard on the slides.
The only thing I can think of is I have run the track very loose at times and I wonder if the clips can get pushed into the rail caps in deep snow. The rail caps are in perfect shape and are both tight (I installed two nuts and bolts in each when the sled was new) so loose rail caps is definitely not the cause.
Another problem I had with my sled on the 2nd ride (when new) is in order to control ratcheting I had the track very tight and this caused the hyfax to wear rapidly at the curve of the rail. The left side hyfax actually overheated and this overheated the left side track clips (they slightly melted into the track at the ends away from the hyfax). I'd expect to see the left side clips only missing, but both left and right sides are missing about the same number of clips. The right side never overheated.
One final note is I am running Skidoo anti-ratchet drive sprockets. With the Yamaha setup I couldn't get the ratcheting under control without the track so tight it ate hyfax. I haven't heard of Skidoo's loosing track clips so I don't think that is the cause.
Its a mistery...
Are any of you still loosing track clips? Have any of you figured out the cause? My best guess is too loose a track combined with lots of hyfax drag (with the overtight track at the beginning).
I guess its time to invest in a track clip tool and a bunch of track clips. Because of this I also plan to change the track very soon.
Its a mistery...
