vmaxcrazy
Do you have the track clips for a 06 Attak? If so, how much?
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
vmaxcrazy - I think we might have talked on the phone earlier today - if not we definitely have those clips - they retail for about $2 each. Let me know if you have any more questions. Thanks
vmaxcrazy
Yes, that was me on the phone. I have the clips ordered along with the rail end caps. Thanks again Kevin. Dave.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Go to www.hiperf.com and look at the anti stab wheel kits. they replace the rail tips and really work. I had them on my viper, and will have them on my warrior too. They really work. Maxdlx
clicker_clit
I have a question that relates to this for the port yamaha people. I was wondering if there is anyway of getting a printout on the rear axle of a 2006 nytro. I recently had the rear bogey wheel nuts completely come loose and fall off while riding. I have parts coming under warranty from the dealer which includes a rail that is backordered until may. This weekend we received alot of snow, so i bent the rail back since it wasn't that bad, and used the two remaining bogey wheels that I found the first time this happened. while riding the idea didn't work. the right side bogey wheel ripped completely off through the bearing. I was wondering where I could get a printout of the parts in the rear end to see what i need to order. also do you deal kimpex wheels?
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
If you go on our website (www.portyamaha.com)we have the complete microfiche for that sled and many others on our website. Just click on the tab that says OEM parts and it will take you to a program that will allow you to enter your sleds info and then view the microfiche with our pricing for all the parts. Once on the microfiche you can print off pictures of each frame of the microfiche if you need them. As far as the wheels go we do have access to the kimpex wheels but in most cases I can recommend a suitable wheel offered by Yamaha either as a standard replacement part or as an accessory that might work for your needs and be more cost effective and durable than the stock ones. Give me a call if you have questions. Thanks
