Track deflection
Well in my 5th post up top i said that others will have more info on this and he should be fine,in my experience with studs.in my 2nd post i would of liked to know how many studs hes running,because the more and the longer "studs" the tighter the track has to be.just info i like to know to give a better answer,but he is not sure on how many or big?? then it led to other talk..but yes he should be fine. the High Performance Slides in the catalog are Graphite,not Duponts.i had great luck with these after i heat treat them with a torch,hot cold hot cold several times.2500mi only half way through.i pulled them anyway and put on Duponts ,cause a got a deal at the show,i didnt toss the Graphite ones out.
