thebest
i have to change my track and i'm not sure if i take a 1" or 1 1/4" #9837 or 9833 they look the same design . i'm not sure with the clearence on the top of the tunnel i want to stud the track. any suggestion?? thebest
LazyBastard
The design on the two tracks is the same. If you want to stud, go with the 1", since it will give you better clearance. You will loose some performance in deep snow though. For no studs, go with 1.25".
