SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
Installed a used drive shaft with extrovert drivers from barn of parts and now I get a weird track rubbing noise going over bumps slowly. Can feel it in the tunnel too. Almost sounds like a chuck of ice breaking off and getting thrown out of track but I am positive that's not it. Have the track tensioned to 1.5 " with no weight on it. Could it be too lose? I don't see any wear marks or anything underneath.
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
Found the issue the rail caps on the front hit the extrovert drivers under full compression. Can I sand /cut then down a tiny bit so they clear????
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Is this driveshaft a Yamaha shaft with yamaha drivers? Or a yamaha shaft with aftermarket kimpex drivers?Found the issue the rail caps on the front hit the extrovert drivers under full compression. Can I sand /cut then down a tiny bit so they clear????
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
Aftermarket drivers on Yamaha drive shaft. Believe drivers are Whal
Brotherdan
- Sep 8, 2017
- Belmont,maine
I had major problems with a Yamaha driveshaft with narrow black kimpex extrovert drivers that someone added on, if you look at kimpex vs wahl you can see the difference, I could not get the kimpex drivers to work &ended up having a newer style Yamaha shaft with factory extrovert drivers cut down in length to match my original & never had an issue again, just a possibility i dont think the kimpex drivers line up properly so they aren’t timed correctly & cause lots of noise & weird track movementAftermarket drivers on Yamaha drive shaft. Believe drivers are Whal
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
Think I found the issue is the front of rails tap the whale drivers and full compression. Did some digging on here and found I have to cut my rails 1/4 to 3/8 of an inch and reinstall caps. XTX issue I guessI had major problems with a Yamaha driveshaft with narrow black kimpex extrovert drivers that someone added on, if you look at kimpex vs wahl you can see the difference, I could not get the kimpex drivers to work &ended up having a newer style Yamaha shaft with factory extrovert drivers cut down in length to match my original & never had an issue again, just a possibility i dont think the kimpex drivers line up properly so they aren’t timed correctly & cause lots of noise & weird track movement
