booxr800
I was just wondering the proper tension of the track should be on the XTX. I know loose is fast and I usually keep it just tight enough so it don't ratchet. But I had my skid out and now I jsut what to make sure its close to where it should be. I don't quite remember but it seems like on my 121 they say if you hang a 15 lb weight on the underside of the track you should have like 2 to 2 1/2 inches sag in the middle of the skid. Does this sound right and if so is it the same for my XTX with the 144.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
loose is slower due to track ballooning at high speeds. Try it both ways and you'll see more mph with a snug track, not guitar string tight but tight. This was the case with both my apex and my nytro.
