Lift back bumper.
Loosen nut on the end of the rear shaft.
Tie rope around the inner portion of the track (ie, around but through the windoes) and hang a 22 pound weight.
Use deep socket #14 and an extension to adjust bolts to pull rear shaft back -- access through track windows.
When track is about 1-1.5" from sliders, stop tightening, remove weight, remove socket, DO NOT tighten axle yet. Start engine, spin the track a few times GENTLY and check track clip to slider spacing. Make sure that its the same on both sides. If not, tighten the side that has the greatest gap and loosen the other side, then spin some more. When its aligned, tighten the axle down. Done.
