stinx
Took my 09 Nytro out for ut first real ride today and I discovered my tral tank is leaking. It appears it weaping out gas by the Fuel pump oring. Any body else had this trouble?
radianguy
- Jan 1, 2007
Wasn't there talk of a different (thicker) o-ring that people were installing??
backstop
Yes Trail Trank sent out replacements for this problem. Speak to your dealer or Trail Tank themselves depending on who you purchased it through.
stinx
I already got the new orings. Believe it or not I think it was just the gasket within the gas Cap was pinched
gormleyflyer2002
mine to
my bib, tank bag and seat got covered in gas this weekend......still not sure how.
my first ride with the TT.....not enough room for the loop from the tank bag and the cap to make it snug. I THINK>
Ironmanstl
I know what you mean, I have to be careful when I fill with fuel, my gas cap gasket falls out sometimes.
It's not the best fit.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The Trail Tank has an updated o-ring for the fuel sender on the side of the tank. The thicker o-ring issue never applied to the fuel pump area. When installing the tanks I have been using an air compressor and with the fuel pump, fuel sender, and gas cap installed pressurising the tank through the over flow nipple and then check all areas for leaks with some soapy water.
