DooAssassin
Here is a vid of my apex. I have a big issue keeping the skis on the ground and the transfer rod is almost tightened all the way too. In this vid it shows the transfer rod doing nothing...maybe im wrong. Look the front part of the suspension is not even compressed when the rear is.
link: http://www.youtube.com/watch?v=sk_wBSFh0QM
ecopter
Do you have your mono shock installed?
ecopter said:Do you have your mono shock installed?
x2 need to install the shock
DooAssassin
I took it out to see whats wrong. Update, Just pulled apart my transfer rod and it had fallen apart inside. What a mass, the bolt is jammed up inside the tube.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
DooAssassin said:I took it out to see whats wrong. Update, Just pulled apart my transfer rod and it had fallen apart inside. What a mass, the bolt is jammed up inside the tube.
Heat the outside of the tube slowly and it should fall out.
