Attak - Transfer Rod clunk?
Barrington, IL / Rhinelander, WI
07 Attak
I hear a clunking coming from my rear suspension while trail riding slow over larger bumps. When the ice melted I investigated a bit a found the transfer rod has some play in it. (See YouTube Video)
Other posts say this is normal but Im thinking I have a worn bushing or spacer. Whats the fix for this?
Clunking of the transfer rod linearly (Along its axis) is normal. I mean the rod inside. You need new bearings in the eyes.
Agree with ramsomair your needle bearing is probably 100% gone with that much movement,I had to change these on mine(be very careful installing new as the oem bearings are a plastic cage&pretty easy to damage
I have removed my transfer rod every couple years and cleaned the needles with Brake Kleen then repack with grease. 30,000km and still good!
I take it I need a press to remove and install new bearings?
You can do it with an arbor press or vise(may need to use a shallow socket depending on size of vice)also there are 2 small shaft seals on either side of bearing that should be replaced.can press in or use a bushing/seal driver set
Wearing out the rod mount due to the slop so the new bearings and seals won't fit properly...just a guess on my part.
If the rod comes apart it could start a #*$&@ storm of broken pieces potentially destroying your track.......worst case scenario.
