Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Yeah don’t drive it with it worn like that,if you wreck the control rod it’s about $150 plus for a used one!!you can remove it altogether but won’t have any ski pressureWith track lifted off the ground transfer rod does not move much at all.
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Yes I broke mine on my attak and all of a sudden I could stand the sled up ! It was fun ! Lol
vipermike2002
- Jan 19, 2006
- Barrington, IL / Rhinelander, WI
- 07 Attak
I should say clunk.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Probably arm pressure on it,just unbolt it&remove it to see what’s worn on that endI should say clunk.
vipermike2002
- Jan 19, 2006
- 07 Attak
Got my impact from my neighbor and removed the transfer rod. The rear bearing is GONE. The front looks OK put some of the pieces inside fell out. All the oil seals are missing. Kinda fucked up the rod removing the rest of the old bearing. I might have to consider buying a good used part ready to bolt in.
Also found some stress cracks in the pivot arm. I can't win. This sled only has 6500 miles bought it with 2100. Previous owner must have ran it HARD.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Those are troublesome. Had the wifes welded once already.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
The newer pivot arms are beefed up a fair bit. I wouldn’t replace that rod, you can purchase the seals and needle bearing assembly from Yamaha. I’m playing the same kinda game right now with a used Mono II I purchased. I’ve managed to save the bearings, but they were rusted and seized to #*$&@. Seems not very many riders maintain their stuff like I do.
vipermike2002
- Jan 19, 2006
- 07 Attak
The newer pivot arms are beefed up a fair bit. I wouldn’t replace that rod, you can purchase the seals and needle bearing assembly from Yamaha. I’m playing the same kinda game right now with a used Mono II I purchased. I’ve managed to save the bearings, but they were rusted and seized to #*$&@. Seems not very many riders maintain their stuff like I do.![]()
The search for pivot arms starts
Priced out replacing all the worn parts on the transfer rod "eyes" about $70. But yeah putting in used parts kinda sucks. I am just worried about bearing removal/reinstall on current rod. Like I said. fucked it up pretty good trying to remove the old bearing on the rear of the rod.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Call Travis at Barn of Parts he's probably got a good used one. I can't believe this happened so many on this forum say the Apex is indestructible and will out last anything. Just go to show they all have issues and one isn't any better than the next one.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Travis at Barn of Parts can likely hook you up with part of a transfer rod, and anything else you might need. He’s a site sponsor and a great good guy to deal with.The search for pivot arms starts
vipermike2002
- Jan 19, 2006
- 07 Attak
I was wondering when and if I would ever see a cracked pivot/w arm. I assumed it happened to high mile or abused sleds. Most of the threads I read yesterday were about people getting them replaced under warranty on few year old sleds so I guess it can happen at any mileage.
